First Engine. A successful Sterling engine
DOC123
Dear All
I purchased a 9x20 lathe to make parts to use on my telescope but decided to try to make an engine as practice. I bought a kit of bar stock with plans and the result was a little sterling engine.
I am not an engineer but a medico so this has been quite a learning process.
Some images are below.
This is turning the central block from a cylinder of aluminium.
Milling the pillar on the lathe using a little end mill from a dremel tool.
making the piston shaft.
the finished engine.
Also I have a video of the little engine going here.
[ame]http://www.youtube.com/watch?v=296Fr_dfdlo[/ame]
Terry
Congratulations Doc :bow: :bow:
Now your hooked.
Psst......how are my new heart valves coming along ??? :-X
Welcome. wEc1
Best Regards
Nice Sterling Terry. Lets see some telescope parts when you've made them.
Vic.
They look like nice little kits those. Well done, especially doing a stirling for your first engine project! :bow:
Nick
Well done Doc....what do you have in mind now for your second engine ?
Bill
A stirling for the 1st engine. And a fine looking and running one at that. :bow:
Congratulations,
Great job on your engine!
Vic.
Thanks all.
The telescope parts I've made are pretty boring so far. An example is below. It is used to accurately attach a camera to the scope.
Nice work well done
I would love to have a go at that engine myself could you tell me where you got the plans from.
Thanks
:bow: Rob......
Hi Terry,great job,keep up the good work and if your ever over at Coffs Harbour Give me a call and come and check out my workshop.
Regards Ian
robwilk said:
Nice work well done
Thanks
:bow: Rob......
The kit came from here
http://cgi.ebay.com.au/A1-3-Stirlin...U_Toys_Hobbies_Model_Kits&hash=item3f02ac95bd
It has a book of quite good drawings. The kit is complete except for screws. I needed to buy the cap headed screws etc separately.
The aluminium and brass pistons and the hot chamber for it come prefab but the rest is all bar stock. I found the brass piston wasn't quite round and it didn't seal well enough in the cylinder that I had made. This meant that the engine wouldn't run. I made a duplicate one out of bronze that sealed better and now it works.
The other modification I made was to the brass stand under the flywheel. The kit comes with a sheet of brass about 1mm thick. The plan tells you to bend this to 90deg to attach it to the base. I stuffed this up so got another piece of flat brass as the vertical part of the stand and screwed a length of ~8mm square brass to the base of it. I then could attach the square brass to the ally plate under the engine.
