Finished Brian Rupnow's Twin Cylinder Engine
kiwi2
Hi all,
Brian Rupnow was kind enough to send me a set of drawings for his twin cylinder horizontal engine. I finished it a couple of days ago.
The main departure from Brian's concept is the cylinders. His drawings call for a piece of 3" x 1" brass which I didn't have and which I would have difficulty sourcing locally. I did have some 1 1/2" hex bar which I got from a scrap merchant a while ago so I made the two cylinders as separate pieces which are screwed onto an aluminium base plate which is in turn secured to the base.
I added a manifold so as to have a single inlet for air or steam. This was somewhat more complicated than would have been the case with a single cylinder block where I could have soldered the tubes in place. As I wanted to keep the cylinders separate I needed to make the manifold removable so it looks a bit clunky with the compression fittings.
I also made the flywheels from steel rather than brass - again for cost and material availability reasons.
The engine is interesting to run. Because there are no pressure dead spots which you get with a single cylinder engine, it can be run extremely slowly. At 3 psi, it goes at less than 30rpm. This makes following the way the mechanism works a lot easier.
Overall an enjoyable build. Thanks Brian.
Alan C.
Nice build like the hex cylinders.Not got mine running yet.Nice to know it runs on 3psi.I still need to get a compressor/air supply.Its a nice engine
Congrats to your nice build and to Brian for a nice simple engine
I am ready to start a new project ? but what
Very nicely done. I have to agree, those hex cylinders really set it off.
Any chance of a video?;D
Hi,
I have a video but it is about 80 Mb. I don't have a youtube or photobucket account so I would need to upload it onto this site in the same way as the photos. I'm not sure if this is OK or not.
Alan C.
Hi Brian,
I'm not keen on using photobucket or youtube both of which want an E-mail address. I don't get much in the way of spam because I don't stick my head up much on the net - I don't use facebook or twitter either.
Alan C.
You can register for a free Gmail account (Google webmail) without the need for supplying an actual email address. Then you can create a Youtube account from there. You never need to access the Gmail account once you've set up Youtube so it won't matter if it fills with junk.
Hi Kiwi2.
MasterPiece by a MasterCraftsMan.th_wav
Gus is still struggling with the Howell V-2. Trying very hard to enjoy making the very small/intricate parts. The gear type oil pump took 3 weeks.
