After a 4 month hiatus, I went back into my machine shop and built something with my milling machine today. I have signed up for "The Canadian Hotrod Tour-2009"--This is a tour of hotrods from across Canada that will drive to Moncton, New Brunswick in July, and visit the Canadian Eastern Hotrod Nationals. It will also drive across the confederation Bridge to P.E.I. and will also go across the Canso Causeway and tour the Cabot trail. My 1931 Model A roadster pickup that I built 5 years ago is a great little car, but when I designed it and built the top, I never made any provision for sidewindows. This is not a big deal for local cruising, but the thought of a 2500 mile trip without sidewindows is a bit much. So---I have designed "clip in" Lexan sidewindows that I will use for the trip down and back. They are not a permanent installation, and are definitly not Hi-Tech--They will slide into a channel fitted to the windshield post, and slip over 2 studs welded to the inside of my convertible top frame. To be held in place by a couple of wing nuts on the studs.--This is the kind of thing where you set the Lexan in the car, then set yourself in the car, then slide the Lexan into the front channel and over the 2 studs and screw the wing nuts in place. --Not terribly convenient, but will be fine for each 300 to 400 mile day. When I'm not using them they will fit into a cloth bag and ride in the back of the truck. (I have built a locking tonneau cover since the picture was taken 2 years ago. So---for $3.00 and an afternoon on the mill, I have the front channels made up---all they lack is a good polishing.---Brian
