I have some blow holes and a depression in a web on the Kiwi crankcase casting. Normally I would fill this with xxepoxy based compound and when painted it wouldn't be noticed. For this model I would like to have a sand (glass) blasted surface which looks really good but-but-but I have these small holes. I thought I could mix some aluminium powder with clear epoxy into a paste and use that as a filler but it is far too dark and sand blasting simply shows it up. I concluded that the resin was not allowing the fine powder to become visible. The next step was to file a block of aluminium and use the filings to make a paste. It worked and could be filed into a slightly aluminium type surface but when blasted it darkened unlike the casting which turned a nice silvery colour.
Do any of you guys have a magic way to fill al castings which could then be blasted. I am dismissing any form of welding or even the low temperature solder sticks as they have the potential to wreck the casting.
My current fall back is to paint the crankcase- probably dark green, leave the cylinder polished and the head black. Brass parts sand blasted and clear mat varnish.
I would appreciate your views
Mike
Mike
