- Jan 4, 2011
- 1,418
- 384
I have an Excello 602 mill. I was wondering if anyone else has one or has experience with one.
There is a seal in the head which should be replaced. When I start the mill after is has not been run for a while I have to place a rag around the spindle or I get sprayed with oil. Irritating but tearing the head apart is a lot of work. I read in an old post in another forum that someone had replaced the automatic transmission fluid with synthetic gear lube and that helped the problem. I have copies of two manuals and one says transmission fluid and one says gear lube. Has anyone either repaired the head or changed the oil?
In researching this I have come to realize that there is supposed to be a return spring on the spindle and the spindle should retract much like a drill press quill and not have to be manually forced up. Even if the spring is broken it is unlikely that I can find a spring to replace it. Excello has been out of business for years.
Anyone know of a source for parts on this machine?
Thanks: Gordon
Thanks: Gordon
