I'm hoping someone here is an expert on adhesives and their properties. I'm fixing some fins to a heat exchanger core using an adhesive. I've made a test rig and have found that the best type of resin for thermal conductivity appears to be a polyester based one, Plastic Padding chemical metal.
In my tests I've found that its thermal conductivity is 3-4 times as good as various epoxy types. I have a couple of issues with it though. Firstly, I don't place a great deal of trust in my test apparatus, although it does seem to produce consistent results. Secondly, the cure time is too fast for me to fill a slot and insert an aluminium fin.
Is it likely that polyester resins have a higher thermal conductivity than epoxy ones ?
If I try to reduce the hardener/resin ratio this should reduce the setting time. Is this a marginal road to go down ? I know I can cool the parts and adhesive to try to slow things down but I don't want condensation rearing it's head.
Does anyone know of a slower setting polyester resin that I could use. I live in the UK.
Free karma point to anyone who can read the above without falling asleep .. .
Many thanks
picclock
Many thanks
picclock
