Hi everyone, I recently acquired a steam engine and boiler both made by Stuart Turner, the boiler is a 501 and the engine is 10V. The engine was a bit of a mess with parts missing and worn so I decided to get it running before any restoration work.
After repairs I hooked it up to my compressor and set the timing, it will run at practically zero psi and runs at high speed well, very impressed and pleased with myself as this is my first steam engine.
So I coupled it up to the boiler to try it on steam, it absolutely refuses to run, it hicks and coughs a bit and spits out water through the exhaust along with a few puffs of steam but that's it. I had the boiler at over 20psi and opened the valve fully which surely should be enough ?
Hooked it back up to the air line and it ran perfect even at very low pressure.
I'm a bit confused as to why it chucks out a load of water and not so much steam, the water sight glass is just over half way up, I checked the valve and the steam line etc. Am I missing something simple ? I'm learning all this as I go along so any help is more than welcome.
