- Jul 16, 2007
- 3,028
- 1,119
Mosey had started a thread on mounting a chuck on a rotary table. I didn't want it to get to far off topic as there was some comment on building a fan for a model engine.
I am attaching some pictures of the fans I made for a couple of my engines. First up will be the 302 engine. The fan is made in 2 pieces. I took some .032 aluminum sheet and cut out the shape that I wanted. For this one I made a small die to press a rib into the blade for stiffness. The tip was then curved. It is mounted with 4 bolts through the fan and hub into the flange on the water pump. I wanted to replicate a full sized fan as much as possible.
George
George
