Elmers #23 Beam doubled.
ronkh
ronkh
Hello gents,
My first attempt at a beam engine (and any sort of engine)! apart from a fancy wobbler also by Elmer.
It's Elmers number 23 beam engine that I have made to double size. Not running at the best yet but that is because it's still to be finished i,e flywheel, rads/corners smoothed out and then painted etc, then I can get it timed correctly. My thanks to advise I had about this from some of you.
Its also not running fast because none of the linkages are as yet secure - everything is still a loose fit!
I'm sorry about the extra bit on the vid but that's because this is the first time I've used my camera as a video recorder. (I forgot to turn the ruddy thing off)!!
I do have a few pics of this build but because my next beam to be built is from a certain J.A.M.De Waal - which I have started and taken pics of so far - I thought that if you are interested, I could start a new build thread of that. I will download a pic of that wheel with a couple of other wheels for comparison plus the size and weight in a later post.
Kind regards,
Ron.
http://s1129.photobucket.com/albums/m516/ronkh1/?action=view&current=SAM_0645.mp4
Bit of a big bugga!
Awesome start !!! It is very interesting to see the different takes on Elmer's engines. I wonder if he had any idea that modelers would be using his plans so many years after the fact.
Looking forward to seeing it completed and running !
nice work, looking forward to seeing the rest of the build.
Brock
Looks very impressive at that scale. Ought to be a great display when running.
