el gringo
- Aug 30, 2010
- 333
- 175
Two years ago I decided to design/build a hit & miss engine using materials on hand that had accumulated over the years of model building. The project became a fun effort between other ongoing projects.
A few months ago I ran it for the first time, it started up and ran nicely with minor fiddling which for me was a first.
The material that had the most impact on the design type were pieces ½ 6061 aluminum plate (frame) , a bar of 2 ½ aluminum round (cylinder & head), a length of ½ x 1 2024 aluminum (connecting rod), a length of 1 ½ square aluminum (gas tank), a length of 1 1/2 1144 Sressproof (crank shaft) two 1 x 6 cast iron discs I had purchased years ago from Enco (flywheels), Cast iron round (piston & rings), odds and ends of bronze (governor system, Chuck Fellows carburetor, crankshaft counterweights & misc.), some local Tan Oak (base), and some nuts & bolts.
The engine bore, and eventual size, was mostly determined by some 1 ¼ I.D. aircraft tube left over from the cylinder of a Leon Riddenour Fords first engine of which I had built three.
The ignition system is a Roy Sholl S/S CDI that I am using on ~15 engines.
Some pictures and video ...
[ame]https://www.youtube.com/watch?v=8WzRpECzHlI[/ame]
[ame]https://www.youtube.com/watch?v=pV8YG_aoGaI[/ame]
Ray
Ray
