I would like to build a collet chuck for my 8x12 lathe. It will bolt on the existing face plate/chuck adaptor. 2 questions:
1) I would like to build it to incorperate a big nut on the front to tighten against the collets so no draw bar. This will enable long stock to be machined. Is this an acceptable method? I see some E3 collet chucks made this way.
2) If I do the above, it will look similar to the image below, but with an external thread on the end. I plan on using cast iron for the chuck (since this is what I have around). Will the cast threads be ok? I will probably make the nut from bronze material and it will likely be knurled and holes for a tommy bar.
Thanks for any input.
Eric
Eric
