Diameter for Threading.
kcmillin
I am having difficulty trying to find the correct diameter to make stock to get it ready for threading.
Is there a rule of thumb here, like a certain percent less that the major diameter?
I always have to make parts smaller than I think to get the die to start.
Also, can this be applied to making threads on the lathe?
Example, If I wanted to make a 1/2 13 thread in an aluminum bar, would I start with a 1/2 inch diameter, or something smaller?
Kel
I guess my question is, Is there an Index for threading like there is Tapping?
Kel (again)
The major diameter of the thread is the size of your material. a 3/4-10 requires 3/4" material, a 1/2-13 requires 1/2" and so forth. This is for male threads of course, if you are tapping holes get a chart. ;)
Kel,
Webs is correct on that.
If you are cutting with a die, you should preferably use a split one. This allows you to leave the two outer screws in the diestock loose, and tighten the centre one into the split. This effectively makes the die cut larger, and so should start cutting a lot easier as well. If you look at either side of the die thread, you should find one side has a fairly large lead in taper, this goes towards the job, again to help start the thread off.
If needed, you could put a small lead in taper on the workpiece, which I do as a matter of course, that way you will end up with a thread that starts much easier into the hole than it would do if it was square ended. After you have cut the first run on the thread, you gently unscrew the centre screw and tighten up the two outers, then take another cut. What you are doing is bringing the thread size down gently until it is a perfect fit into the internal threaded hole, you might have to take it down in a few stages until you reach the good fit size.
This tapered lead in does have one disadvantage. It leaves the threads at the end of the cut tapered as well, so they might not screw all the way into the threaded hole. The way around that is to cut a recess into the workpiece to the thread core dimension, this should be the same width as the tapered bit left after cutting the thread, so allowing the thread to go all the way into the hole. Another way is to turn the die around in the diestock, and use the non tapered side to cut the tapered end at the end of thread cut, so you end up with a parallel thread all the way along.
Confusing ain't it
Bogs
The formula for the size of the tap drill, which is also the size of the hole to bore when single-pointing internal threads, is:
TD = MD - 0.013*DOT/TPI
where:
TD = tap drill diameter
MD = major diameter
DOT = desired depth of thread expressed as a percentage
TPI = threads per inch of the desired thread
It sounds like Kel is looking for info on male threads.
I read somewhere, and use this in my shop, go 95% of the diameter. So if you wanted to cut 3/4" threads with a die you'd turn the part to .713 than thread.
Thank you all for your information.
What my real problem is in making male threads. I have all the charts for tapping. But whenever I try to make threads using the lathe or with a die, it never works how I want it to. When I am using a die, it wont start unless I go .010 smaller than the diameter of a screw with the same threads. Anything larger and it just ruins the threads.
I can see my problem is more than likely poor quality dies. I should invest in better dies.
However, when I try screwcutting on the lathe, the threads are always the wrong size, and dont fit the nut.
When I measure an off the shelf 1/2 13 bolt, the outer diameter is .490.???
Sometimes when I start with say .5 inches, when I am done it measures larger than what I started with, like .515.???
I have put this off long enough, I see many people make threads on the lathe with no problem, I should be able to do it too.
So, I think I need some information on threading.
Is one half the difference between the major diameter and minor diameter, the depth of cut?
sorry for such a weird question. It seems I am the only one with trouble making male threads work. I am most certainly doing something wrong.
Kel
Thats it. Thanks Twmaster.
See if this helps. Also chamfer the end of the stock to help get the die started. Buy a good quality die. The cheapo's will make more damage than thread.
I seriously doubt that.
I find it interesting that some lathes are set up to do thread cutting and others are not. That, for me, is a clue.
One of the first things I asked about when I joined the forum is about thread cutting. And while there were some very helpful responses..I have yet to do any serious thread cutting other than with a die.
Keep at it. I'll be interested in finding out what you learn. I could use it.
For external threads the Maximum for a tight fitting Class 3A thread is usually the major diameter. The ranges for a 1/4-20 are as follows.
Class 1A
Major diameter .2367-.2489
Class 2A
Major diameter .2408-.2489
Class 3A
Major diameter .2419-.2500
For most work you'll be using 2A fits. The nominal is .245. That works out to 2%, but this figure is variable being a larger percentage for smaller threads(3% for 2-56), and smaller percentage for larger (1.4% for 1/2-13)threads.
If you turn the stock to the major diameter you'll end up with sharp threads that may not finish well, they tend to roll over, and will be tight in a tapped hole.
I shoot for the middle of the given range for the specification on the thread. If it needs to be tight I make the tapped part first and sneak up on a nice fit on the external thread.
The Machinery's Handbook is handy for this kind of info. When I worked in aerospace every thread and fastener had a class callout.
Greg
kcmillin said:
...When I measure an off the shelf 1/2 13 bolt, the outer diameter is .490.???...
That is only a difference of .005" per side. The material may vary that much (or more). I was taught to always use the full major diameter. If you are using a die to cut the threads you should be using a split die opened up to cut over-sized, then gradually tighten the die until it is on size. A hex die is generally used for chasing existing threads and will most often result in a ragged, undersized thread if used on full sized material.
I really enjoy single point threading on the lathe so I rarely use dies.
As Greg has noted, material that is the nominal size will result in a Class 3
thread. That is at or very close to 100%. I have done a few jobs at work where
that was specified, but not many.
A Class 1 fit is perfectly acceptable for almost any thread in hobby machining.
A 75% to 80% thread is usually sufficient.
If your finished threads have sharp points at the crests, your OD was too big.
Rick
Rick
That's where I want to be. :)
Thanks Rick. Yes I have been seeing sharp points on the crests, I will most definitely be using the method you described.
A side note to this. I have been trying (recently) threading using a spindle hand crank. I feel I have more control this way, but the chips (swarf) is most irregular. Everything is sharp and setup properly, but the aluminum is lumpy looking, like regular swarf but with a nasty case of acne. Almost like scooping ice cream. The cut still looks clean though. I am using a pre sharpened bit that is flat on top. Should I grind this bit that is supposedly made for the job and put a rake on it? Is it better to cut under power?
Kel
Kel...
Are you using a lubricant? Is the aluminum perhaps a gummy nasty to cut variety?
This thread has the table I use (based on one of Marv's formulas, backed up by data in Machinery's handbook-- basically it pre-cuts the flats at the top of the thread, which makes threading with a die much easier since you don't have to plow off that metal during threading). It works well.
http://www.homemodelenginemachinist.com/index.php?topic=6487.0
Direct link to table PDF: http://www.homemodelenginemachinist.com/index.php?action=dlattach;topic=3554.0;attach=1602 Turn stock to "ext thread dia" and go to town ;)
I love this place.
;D ;D
Thanks Shred
Kel
Kel,
Most of the cheaper thread dies from our Asian cousins have no tapered lead in, hence the need to reduce the diameter to get them started and to allow for the "roll up" when the are deforming, (rolling), the thread rather than cutting it. Good quality dies have this lead in and cut more easily and straighter. In any event it always pays to make a chamfer on the leading edge to make starting a die easier.
Hope this helps
Best Regards
Bob makes another valid point.
I have a VERY CHEAP, carbon steel tap and die set that I bought at a local surplus
store for $8 USD. It was Pacific Rim manufactured.
Cheap as it was if you look closely at the dies you can see the difference between the
starting side and the back side. The starting side has a lead in chamfer on all of the lands.
On the back side the lands come to sharp points.
If you attempt to start any die from the back side the result will be frustration.
Rick
Some time ago I drew a detailed diagram of a 60 deg thread form and worked out the formulae for virtually every dimension of interest associated with this thread form. I've attached this to this post.
I encourage all of you to copy this diagram and put it in your shop notebook. It will answer many of the dimensional questions you may have about threads.
If you look at it, you'll see that the the small flat on the top of the thread, which accounts for the fact that the measured diameter is less than the nominal, is made by cutting off a small triangular section whose height is H/8 where H is the total height of the thread.
Near the bottom of the diagram you'll see a formula for 'U' labeled the "diametrical undercut from nominal diameter".
U = [sqrt(3)/8]/n = 0.2165/n
where:
n = pitch expressed as tpi
The nominal diameter of the stock should be reduced by this amount before threading.* I believe that what Shred has done in his table is calculate the resulting diameter for common bolt sizes by subtracting U from the nominal diameters. (Shred, please correct me if I'm off base here.)
For some reason (perhaps an innate aversion to math), machinists seem to like tables better than formulae. I'm just the opposite. I can't (and don't want to) memorize a whole table but it's easy to memorize a formula. Knowing the formula allows me to figure out what I need even if the table is not to hand but, more importantly, it makes it possible to deal with oddball threads that aren't covered in the table.
* While this is technically correct, I have to admit that I seldom do it. I've threaded literally hundreds of things by simply applying good split dies to nominal diameter stock. I believe K's problem is due to some other problem - perhaps bad dies.
