I have intentions to build a full scale, single-cylinder, air-cooled, 4-stroke motorcycle engine based on a 1906 design. I will be using weldments, scrap steel, and bar-stock. to construct the various parts. The engine is based on the 1906 design outlined in the Hasluck book. Bore: 2-1/2" - 3" & Stroke: 3" - 4" approx. Commercially available timing gears, and intake and exhaust valves, tool-steel cams, alloy steel push-rods, lifters, rocker-arms.
The book calls for castings made from cast-iron for the cylinder, piston, head, etc. I will be using steel tube for the cylinder, maybe Aluminum for the cooling fins, and scrap steel for the head, and some other not too critical parts..
Can I use a steel cylinder, with a 6061 Aluminum piston/cast iron rings, or would a cast iron piston/ring combo be more durable running against the steel cylinder?
While this engine will be approx. a full-scale recreation, it will be only used for demonstration at shows, etc. It will not be a "working" engine. Recommended fuel is low octane Coleman's
Please suggest material(s) for fabricating these parts. Include options, alloy names, etc.
Con-rod
Piston
Crank-pin
Rocker-arms
Cam and lifters
I ask because what works for small model engines may not work well for a full-scale engine. I would rather over-build the engine for extra strength. Weight is not a factor.
Thanks for any help you can offer.
Frank
Con-rod
Piston
Crank-pin
Rocker-arms
Cam and lifters
Frank
