what do I use.
1) a dremel tool for cutting HSS bits
2) a small shear for small flat steel
3) a 4 1/2 grinder with cutting blade for smallish steel
4)
for small diameter stuff
5) a grizzly table top wood working saw that is geared down
cuts brass and aluminum wood and plastics. .
6) horizontal band saw in garage for bigger stuff like 3" cast iron or pipe.
7) Hack saw if I am really desperate.
8) bolt cutters
There are many ways to remove the fur of a feline.
1) safety first then use the tools you have or can find cheap.understand the safety risks of all the options .
2) there are lots of options I have also used porta bands, and table saws, cutting torches ,plasma cutters, cold saw 14" abrasive saw for cutting metal.
The horizontal band saw is probably one of the best options for the home shop.
you are not holding the part or the tool . so low risk of something grabbing,whacking, cutting ,or otherwise harming you.
Lower noise than other tools (except hack saw)
less dust to harm lungs.
does not throw sparks.
will cut most metal types.
