Gordon
Historically, there was great animosity between owners of the Quorn and thee thn embryo Tinker.
As Professor Chaddock was in the 'In' crowd and Norma Tinker was in his little shed in Long Eaton, Nottingham, there was no competition really.
So scrapping the rest of my flagging memory, the Tinker I my guess has fairly similar tool holding which appears in all sorts of other cutter grinders. One is 'classic' to most grinders and that is 'a finger' to hold- say a 2, 3 or4 lip cutter. Again, a finger can allow a cutter to follow a flute.
This, I find is now part and parcel of an ER32 tool holder which swops with the more simple holder which is nothing but a 1" tube( in many) which has a series 2BA grub screws. Yes 2BA- what a lovely thread.
Further 'indexing' on the Tinker is to put crude divisions on each end of a ring to fit the notional 1" or 25mm tool holder. The Quorn one, which fits the normal 1" tool holder has detents as well as a 360 degree ring which both indexed and locked with an expanding collet.
Of course GH Thomas produced the dividing head with one hole but two Acme screws which will create ANY angle.
Then, if you must, you can fit an elliptical or epicentral chuck - if you are unto ornamental turning.
You will add all sorts of holders to suit your own needs as you familiarise yourself with your machine
Then- isn't it the Formula for creating angles on a grindinder with 0.006 x the angle required times the diameter in inches on the perifery of the grinding wheel
It gets addictive-- sorry!
