https://www.youtube.com/watch?v=AuS6HDHc7XE
Has anyone here made this before? if so where would i find the meaurements.
Very good video, he makes it look very easy.
Article for cubes was in 'Digital Machinist' some years ago, I made the cube at that time but never completed the final cut that would separate the rings, picture attached.
Emgee
They are great fun to make and you can test your skills and the limits of the materials to the limit. I have turned many on lathe over the years but now make them on a small CNC mill with two cutters and 3 G codes to produce 4 blocks in a 65mm square wood block. It is simple enough to draw out on paper in cross section add take your dimensions off the drawing especially if you draw it 5 or 10 times oversize.
ck
.I am currently making another slightly different
and thinking of making a dedicated ucut tool. Will post when finished
