Hi all, ive had some requests for more details of the cringle turbine model.
Il record a full build log here with plenty of photo's.
Il be making a set of 3 so you may see some parts shown more than one off.
Hi mark, i have seen the pics of your genset before now. Realy nice work! That turbine rotor is a work of art!!Fascinating little job, it's not unlike my own steam turbine generator (see my avatar or more pics of it here Genset pics
This looks like a Stumph turbine where the steam admission it is straight on tangential to the rotor. Mine is a DeLaval type where the steam comes in from the side at about 30 Degrees to the rotor
Where did you get the kit ? I might possibly have a go at one of these myself.
Doing the curved exhaust pipe looks a bit tricky, it looks like the castings aren't cored so you are going to have to somehow bore out this curved hole.
Best Regards Mark
Best Regards Mark
Hi Luke
Great idea, In fact the steam pipe was originally lagged in just this manner but I had to take it for off for some reason during one of it's many modification rebuilds and forgot to put it back on again.
This turbine, like yours I expect, was not exactly designed from the get-go. It sort of evolved through many experiments and tweaks. Not all of them were successful, indeed some were outright failures.
I am not alone in this however as even today turbines are a little experimental and unpredictable, and on a small scale like this even more so.
Both Gustav DeLaval and Algernon Parsons had their share of "epic fails" and Sir Frank Whittle had some spectacular, explosive ones,
I eagerly await the steam nozzle bit of your project as this is a VERY critical component and I had several tries before I got it just right.
Ideally it should be like this. and getting the throat diameter just right is tricky, too small and you don't get enough steam flow, too large and you get plenty of flow but not enough velocity.
You will soon know when you do get it right, as I did !
In early days of testing the turbine I was running it unloaded testing various nozzle sizes and Geometries and one day as I slowly increased steam pressure it suddenly hit a point when it accelerated wildly and then suddenly became much quieter. It was drowned out by the sound of every Dog, Cat, Sheep, Bird and other sundry creatures within about 1/2 a mile making the most horrendous racket.
What had happened (As I found out later) is that it was going so fast that it's blade frequency had actually gone ultrasonic, I couldn't hear it but all the animals could !
I Suspect you now suffer from a condition called "Turbinitus" I also have it. It's quite incurable, and rather contagious, but great fun if a little frustrating at times.
So keep at it and I can't wait to hear 'em spin up for the first time.
Best Regards Mark
