As is often the case on a project that has a lot of mis-starts and re-starts, contemplating the NEXT project is always much more exciting. Something new and shiny!
I've seen several threads about diy dynos, some successful, and others, not so much. I like to think the theory through, just enough to convince myself that the new project is a great idea and I should dive right in, LOL. A minimal amount of research, and a lot of spreadsheet calculations must obviously be done, because that is the fun stuff. Then, after a few weeks, and having a very squishy plan in my notebook, I will look into what others have done, and what might even be available for purchase. Because my time is worth..... zero....???.... , anything that is more expensive than the cost of the materials is too expensive. (Still making the same mistake.)
I noticed in one of the junk sheds an old recumbent exercise bike that had "Programmable Magnetic" emblazoned on the side. After some very brief troubleshooting research online, I stripped the side covers off and discovered that the magnetic brake "load" was much smaller than expected (one of those "point and laugh" moments). But after some quick calcs, it looked like the brake might be good for a steady 700 watts or so, which seemed reasonable because it was a good bike, and 700 watts is in the range of what a fairly fit person can sprint on a bike.
Here are the details of the mechanism from an Edge 491 recumbent exercise bike.
Crank Radius, 5.4"
Applied force on the crank, 100 pounds (a reasonable guess).
Pedal RPM, 100
Estimated torque, 45 lb-ft
Belt overdrive ratio inside the exercise bike, 7.7 to 1
Torque at the magnetic brake assy, 5.84 lb-ft
RPM at the magnetic brake assy, 770
Horsepower produced when maintaining 100 pounds force on the pedals at 100 RPM
---- 45 lb-ft * 100 rpm / 5252 = 0.857 HP = 639 watts
639 watts isn't that great, but the magnetic brake inside the flywheel only has 2 permanent magnet shoes, 2 more could be easily accommodated. The brake-shoe-shaped permanent magnets do not rotate so their exploding is not likely. They ride inside the flywheel like a pair of brake shoes, but there is no contact inside. The resistance force is increased by moving the magnets outward so that they almost contact the steel flywheel. Resistance is reduced by retracting the magnets, using a tiny motor to pull a small cable that pulls the magnets toward the center of rotation.
The total mass of the flywheel is 3.38 kg, and has a mass moment of inertia of 0.0355 kg-meter^2. I need to do more calcs to see if that is too small to be of use for an inertial dyno.
My understanding is that a true inertial dyno can only capture data as the engine is accelerating the flywheel. The angular acceleration of the flywheel, and its MMI, are used to calculate the watts (or HP) as the engine rpm accelerates to its max rpm. If the engine rpm is at steady state, with zero acceleration, then (theoretically) no work is being done that an inertial dyno can detect.
So, if the engine is at a steady rpm, the magnets can be used to brake the flywheel enough to pull the rpm down, and the torque-arm reaction of the magnetic brake framework will yield a measurable torque, which combined with rpm, will facilitate calculation of HP or watts.
It sounds feasible, but I will have to sleep on it several nights. Because I want to document the output of a small, slow diesel, I think having the capability of measuring steady-state torque is paramount.
Here are pics of the cannibalized exercise bike. A different type of dyno might work better, but I don't know. The magnetic brake assy is 9" dia flywheel with the folding rule across it.
Any thoughts?
Thanks,
Lloyd
Crank Radius, 5.4"
Pedal RPM, 100
Any thoughts?
Thanks,
Lloyd
