- Jun 4, 2008
- 3,290
- 635
Having gotten my new mill (Novakon NM-200) installed and running along with mach3, I decided to make a part. The one I chose was an outer main frame for the ER Westbury side paddle engine that will be my next "big" project. I chose this part since it is fairly complex. That might be the first mistake, as doing a simple part first might be more sensible. Other than that, I learned a few things the "hard way.":
1) Endmills don't like cutting deep slots (i.e., 3xdiameter) in 6061, esp. w/o coolant. (scratch one .25" carbide em)
2) Non-centercutting endmills can't cut slots of any depth unless starting from outside the stock (scratch one .25" HSS endmill)
3) When mounting on sacrificial stock/fixture, make sure that the fixture will fit in your vise, and if it does that any bolts/screws used ton hold it are outside the toolpaths you will need.
4) When making a part with an irregular contour like this one, the stock needs to be mounted on the fixture for the duration. In this case, I had a couple of holes that could be drilled through the stock and fixture for securing with bolts. To do this, the holes need to be reamed and a precise pin pressed into the holes to obtain reliable repositioning. Of course I didn't do this. In then future I plan to use 2-sided tape.
5) Trim the stock as close as possible before mounting to the fixture. In this case, a roughing endmill would have saved me a lot of grief.
While Westbury made his frame pieces from steel, I decided to use 6061 aluminum as I had a piece of scrap that was close to the right size. For the next attempt I'll plan on using steel myself as the swarf is less likely to stick to the endmill flutes.
