- Jun 24, 2010
- 2,447
- 969
Looking for some input. I purchased a dividing head with 1.58external/male threaded spindle. Ive been eyeing a 5chuck to use with it. A semi-finishedcast iron back plate was included with the DH & they are also commerciallyavailable. Its already threaded 1.5-8 but the rest of the surfaces are notfinished. From what I can tell, if I selected a plain back chuck, I would have tomachine the back plate on all surfaces including a ledge on the front face thatmatches/engages a recess in the chuck back, plus drill/tap the chuck mountingbolt holes.
Im only guessing here, but maybe these semi-machined platesare more intended to be finished for end use on lathes with 1.5-8 threaded headstock? Ie. screw the rough plate on, machine the OD, face & ledge. Then itsalready axial & ready to mate to the chuck flush?
But my lathe is D1-4 so not really an option that way. Howwould I mount the rough plate properly in my lathe chuck to ensure the ID threadsare perfectly axial before carrying on with the rest of the machining? I canvisualize gripping it, but could I expect to accurately dial in on the skinny,winding ID threads? I thought about making an adapter stub with 1.5-8 threads& similarly screw the plate onto that? But for that effort, maybe better tojust start with a slab of material & machine the ID threads + OD + face stepall in one turning operation? I dont see fully finished 1.5-8 backplatesavailable. You can get a ready to mount 1.5-8 threaded chuck, but I think theyare kind of integral/permanent?
Which brings me to issue #2. Ideally, Id like to alsoutilize the same chuck body for a rotary table or even on the mill table. Itwould be nice if the 1.5-8 backplate could detach, leaving me a flat datumsurface on the chuck backside to mount directly or a separate (non-threaded)plate. Hope this makes sense.
