Newbie here, on the learning curve. My current questions are about selection of materials when making a bar-stock build.
First, here is what I think I have gleaned from reading through a number of builds:
Aluminum seems to be the material of choice for a large percentage of most bar-stock builds - frame, head, valve block, rods, carburetor, other odds and ends.
Bronze or brass for plain bearings; oilers and sometimes gears are typically from brass.
Cast iron for the majority of cylinders, and for pistons in about half the builds I've looked through.
Steel seems to be used for crank shafts, pushrods, valves, and cams, though occasionally someone has referenced using steel for the cylinder.
Flywheels seem to be the most diverse in choice of metal, depending on what the builder has on hand.
Now come the questions:
Is there any reason one couldn't use steel more extensively in the build, e.g., for the frame, head, valve block, and rods? Obviously steel would add more weight, but all of it static weight except for the rod - would steel here be too much reciprocating mass?
What are the advantages / disadvantages in using dissimilar metals for the cylinder and head? It would seem like the aluminum head might want to expand more than the cast-iron cylinder, for example - ??
I've never seen anyone mention using steel for the piston - is this a really bad idea? (Again, it would add weight to a reciprocating part, as compared to aluminum, but no more weight than a cast-iron piston, I think?)
As an explanation for my questions: some of this is purely a matter of learning about what goes into the best-practice of a model IC engine, but some reflects the experience and materials I have on-hand. In my 10+ years of home-shop machining, I have acquired (scavenged!) quite a bit of steel from various sources and in all sizes and shapes, but relatively little aluminum, and most of that in small bits and pieces. Most of my machining experience has been in steel, with only a tiny amount in aluminum. My shop equipment has no problem handling steel, and in terms of speeds available, is arguably better suited to steel than to aluminum (Series I BP goes up to 3000+ rpm, but my Cincinnati 12-1/2 x 30 lathe tops out at 1200). Finally, if it were necessary to do any welding, I have a decent DC tig welder, but no ability to weld aluminum.
All that to say, as I have thought about trying my hand at a build, I could easily complete something like a Webster with materials on hand IF I could build most of it out of steel, including the cylinder, rod, and head. I do have a couple of small lumps of cast iron that would be sufficient for making a piston, and plenty of bronze and brass for bearings and valve cages and such. I have enough small bits and pieces of aluminum that I could make the valve box from it ... but I've also got plenty of small bits and pieces of steel that would serve. Perhaps most important, I have enough of all of the above that I could easily re-make parts if, or rather when, I mess them up.
Given that I have plenty of home-shop machining experience, but NO experience building an IC engine ... would I be setting myself up for trouble if I went this route? Half of me says, just buy the materials you will need. But the other half of me, the scrounging half, says "why not try with the materials already on hand?" (That latter half got louder when I priced a bar of cast iron from McM-C!)
Thanks for the words of wisdom to come, as well as all that I have already gleaned from reading through the posts on this forum!
--Andy
--Andy
