What do you mean, set it back?View attachment 112707 this is their up right model
Has any one had any problems with their ignition I received the engine installed the battery's and it worked on test I set it back. when I added fuel I get no spark out of the system
What is all the extra wiring you have running to the engine?
Hope you're not running off an external 12v battery or similar.
Notice original HT lead disconnected.
No ignition should be run with HT disconnected, quickest way to destroy any electronics.
Instructions are typical Chinese and mention 3 x AA cells to be fitted in the base box but then they say voltage rating is 3.7v.
Three AA dry cells are nominal 4.5v.
Was mention of ignition system failure due to overheating in one comment on Banggood.
Whether that was the correct failure diagnosis or not is another thing.
https://www.banggood.com/Eachine-ET...ne-Collection-p-1549664.html?cur_warehouse=CN
As for the 50% throttle claim above, just a load of cods wallop.
Once an engine lands in consumerland, no telling what conditions it can be subjected to.
I think you'll find the spec referring to 3.7v is commonly associated with nominal voltage of a lipo.
Agree with the 3 nicads however they are all but obsolete these days in many places.
