Ved
I see. I assume the impeller blade is milled just by offsetting the rotary table chuck.then indexing accordingly. Are there any calculations or just an eyeball set up for the first blade.then the rest follow.
Most of the aquarium pumps I've seen have straight vanes. The simplest have a volume that is circular, but eccentric of the rotor. The vanes slide up and down in a slot being flung against the volume as they spin.
This could get way technical - but for simplicity you don't have to look any further than the coolant pumps on virtually all car engines.
Appallingly inefficient but they get the job done.
I sell water cooled welding equipment and those pumps have straight radial vanes (not even offset or curved) and it does the job.
What do you need ? If its just to circulate coolant almost anything will work.
Ken
