I stumbled across this thread today, and somehow I missed it entirely when it was posted; perhaps it got posted before I joined here (edit: checking my join date, indeed that is the case).
Not sure how I found it exactly, LOL.
I was searching for something, and there it was (ain't old age great? you don't know where you were going, or how you got there, but you like what you see when you get there).
I got the backyard casting bug in 2011, and started playing around with burners and simple furnaces made from stacked bricks.
I used a welded steel pipe for a crucible.
I melted aluminum for a while, and then saw someone online who successfully melted iron with an oil burner, so the quest for iron was "ON"!.
Six years later (on and off trials as work allowed), I finally mastered melting and pouring gray iron.
I learned a lot about pouring aluminum along the way.
I cast the engine in my avatar in 356 aluminum and gray iron (flywheel in gray iron).
There has been some debate about the techniques for degassing aluminum, with some using washing soda, and some using pool shock (toxic fumes).
I tried the washing soda, but I found that the gassing that it does when plunged into molten aluminum is caused by it absorbing moisture, not by the aluminum releasing hydrogen or any other gas. If you dry the washing soda an oven, you will get no gassing after plunging it.
The best way I have found to avoid gassing in aluminum is to bring it quickly up to pour temperature (I think I have been pouring at 1350 F), and then immediately pour. If you overheat aluminum, or let it sit for any period of time after it reaches pour temperature, it will absorb all sorts of gas.
I have had good results using this method, and have not had to resort to using pool shock or any other additive.
There is a bit of an art to casting things, and for long thin pieces, I have found a knife gate to be very effective.
I knife gate runs down one (sometimes both) sides of the mold cavity, and is connected to the runner.
Nice work in the flywheel.
Edit:
I use an oil burner with a siphon spray nozzle, and a leaf blower for combustion air, to melt gray iron.
I use a Morgan Salamander Super clay graphite crucible with iron, and use a separate one of the same type also for aluminum.
The crucibles can be purchased in many sizes on ebay.
The trick with melting iron is to use about 2.7 gallons/hour of diesel (some use waste oil, I do not), and adjust the variable speed leaf blower to get about 3" of flame out the lid opening.
The furnace needs a good refractory with iron melts, and I use a castable refractory called Mizzou.
Some use ceramic blanket coated with I think bentonite, and that will work for a while, but probably not as long-life as Mizzou.
Mizzou is rated I think at 2,900 F.
Edit2:
Not to highjack this thread, but here is a link to my videos that I think works:
Lots of trial and tribulation in these videos. I tried many many things before I got a good working format to pour iron successfully.
https://vimeo.com/user82094693I used the spoof screen name "Raphael Mantegna" to try and throw the telmarketers and other sales shammers off the track (I am Pat J).
