Good day to all,
Whilst machining one of the cylinder block aluminium castings for my 1/4 scale Merlin project I have discovered a small defect, perhaps a porosity that has generated a small hole ~1mm wide by ~2mm high at one end into the cooling water volume. Light shining through makes the white mark you can see to the right of the casting picture.
I guess Murphys law says you need to have done at least some of the machining to discover these things!!
Would any of you good people more knowldgeable than me have suggestions as to how best to remedy this issue?
Any comments/suggestions/remarks would be most appreciated.
Lloyd.
Lloyd.
