Skipper
Where can I get some cast iron with a lot of grafite?
skipper
skipper
Making piston and ringSkipper,
What application will this cast iron be used for?
Chuck
I'm looking for some too, but I haven't visited my second favorite scrap yard yet. I'm waiting for next month to see if Ihave any money left. I can get many grades of steel there and many unknown grades. But cast usually is more difficult to find. I am going to try the cast iron of hydraulic cylinders, hoping that it is machinable. Maybe it is not CI but steel. They cylinder is already formed but of an already made size. The rod might be usable too, except I thimk it would be too tight.One way come iron is scap yards.
You would need that what small amounts but the out there.
I have used dumbells too. Just use hole saw for blanks.
I believe hydraulic rods are a harden able steel like 4140 and I don't think the cylinders would be cast iron either. Cast iron would be to brittle for that kind of pressure.I'm looking for some too, but I haven't visited my second favorite scrap yard yet. I'm waiting for next month to see if Ihave any money left. I can get many grades of steel there and many unknown grades. But cast usually is more difficult to find. I am going to try the cast iron of hydraulic cylinders, hoping that it is machinable. Maybe it is not CI but steel. They cylinder is already formed but of an already made size. The rod might be usable too, except I thimk it would be too tight.
I was thimking CI might be too brittle for those pressures (even so, they are VERY thick which is part of the reason they attracted me) but the cylinders LOOK cast, maybe they are cast steel? If so, they are probably hell to work. Maybe one could anneal them?I believe hydraulic rods are a harden able steel like 4140 and I don't think the cylinders would be cast iron either. Cast iron would be to brittle for that kind of pressure.
It would be easier to find charts of spark forms. I have seen them but don't remember where. I know welding books and machining books have shortened forms of these spark charts.Grind on one? Granted, if I ground on a piece of metal to see what it was, I'd have to spend an hour looking at YouTube to know what the @#$% the sparks meant. But I know it's informative.
Bollolocks! if you machine cast iron the whole place is clittered with nfree carbon that notonlygets into your fingers but your hair and a lotof othr unmentinable places which i~m am Too much of a gentkeman to eaborate. However, you will add your own expletives when you have to clean down your precious lathe bed. Mildsteel ground makes pretty sparklers for the Carthorse Julie and probably events created by our former colonies.It would be easier to find charts of spark forms. I have seen them but don't remember where. I know welding books and machining books have shortened forms of these spark charts.
