Hi folks, hoping you can offer some advice. I recently bought the plans for a 17.5cc single cylinder four stroke from CAD+Modelltechnik Jung in Germany. (http://www.cad-jung-shop.de/epages/62479729.sf/en_GB/?ObjectPath=/Shops/62479729/Products/00-Z0001-0). This is to be my first engine project, thought I should get a proven design under my belt before trying to draw up my own. Although the plans have no instructions, the drawings are all very clear and detailed, very happy with them. I've had to translate the material specifications from the German standards listed to UK or US specs, but that wasn't too tricky with Google's magical help.
The problem I've got, is that I really don't like machining cast iron, and this engine specifies a cast iron liner and steel piston ring. I'm already planning on swapping them around and using mild steel for the liner with a cast iron ring, but is there any other material I could use for the rings that would eliminate the cast iron completely? I read somewhere that high carbon steel rings are compatible with mild steel liners - does that sound right?
(I've machined cast iron before and it made a terrible mess of my lathe, plus it isn't the cheapest material to buy)
Thanks very much for any help. Will be starting a build thread once I begin cutting metal.
Olly
Olly
