firebird said:
Hi
I need to fabricate some parts for my portable engine, a cylinder block and axles etc. Having had some success using a brake cylinder on my beam engine ( albeit an aluminium one ) I have been looking at some cast iron ones but need to build them up with saddles and valve chests. Does cast iron and steel silver solder, if so any tips would be really useful.
Rich
Not sure about cast iron but you can hard solder steel. I have hard soldered 1018 and some other steels, except stainless.I use a 10% solution of hydrocloric acid for a pickling solution and standard white flux for ferros metal.The steel has to get red hot,more like orange to my eyes. Then the silver solder will flow.
Make sure there is a slight gap ,.002/.004 between the pieces so the solder will flow thru.A few dimples with a center punch will suffice for the gap.
When the stock has cooled down ,place the steel back in the pickle for ten minutes .
Then thoroughly wash and brush with a steel brush until the flux is cleaned off.
Wash thoroughly several times and then dry .The acid promotes rust, if you do not clean the pickle adequately you will know it the next day.
I imagine you can dispel the acid pickling if the parts are very clean. I use the pickle for added ease in cleaning the steel.
You could try this with cast iron if you have any scrap.
There are other pickling solutions that may work, possibly sulphuric acid or even citric acid.I did try citric acid once but on brass not steel or iron.I left the parts in the acid over night, worked fine.
mike
