Runner
- Feb 10, 2011
- 124
- 17
Hi all,
This is only an exercise. I have spare gear wheels for my 9" Southbend Type C Lathe. I want to cut a worm gear that would mesh with a gear wheel and I am unsure of the diameter and the TPI that the worm gear would need to be. For ease of presentation lets say that the gear wheel has 44 teeth, has a major diameter of 2.55" and a root diameter of 2.3", it has straight cut teeth and 0.25 " thick. Using schoolboy arithmetic the mean diameter of the gear wheel is 2.425". The circumference is (22/7 X 2.425) 7.62" and that the pitch of the teeth is (7.62/44) 0.173". The TPI therefore (1/0.173) is 5.78. This would be the same for all the gear wheels irrespective of size. I can cut either 5.5 TPI or 6 TPI, which would be better suited to mesh with the gear wheel? That is the easy part. The diameter of the worm gear is beyond my ability to determine. The parameter to consider on the worm gear is angle of the helix (I don't know if I am using the right terminology) with a small TPI it is quite large, so with a straight cut gear wheel which is relatively thick (0.25") there is going to be some interference between the worm gear and the gear wheel. The way to reduce this is interference is to have the diameter of the worm gear large, effectively reducing the angle of the helix and/or widening the gap between the teeth of the worm gear. How do I calculate the diameter of the worm gear that would mesh reasonably well with the gear wheel?
Thanks in advance.
Brian
Thanks in advance.
Brian
