chucketn
Senior Citizen
I am getting ready to mill/drill the steam ports for the C.W. Woodson Vertical Single, from the April 1947 issue of Popular Science. My build is not exactly to plan, so I have to make adjustments as I go. I cast the cylinder in aluminum, and lined it with a steel sleeve. My cylinders bore is 1 1/8, where the plan calls for 1 ¼ bore.
My first question is, if running this engine on compressed air only, do I need to scale the port sizes up or down?
Next question, does anyone know of a good build thread or video on milling/drilling the steam ports? This is my first steam engine of this type. My available small diameter mills are 3 mm and 1/16, both 2 flute or slot drills. I plan to drill out the port faces slots and clean them up with the slot drills.
Chuck
Chuck
