chucketn
Senior Citizen
I have built Harold Halls Deluxe Grinding Table, http://www.homews.co.uk/page145.html, and am slowly setting up my grinding station. I am also working on the accessories for the table. I have built the lathe tool jig, and the round tool jig, and am working on the drill bit jig.
I purchased a dedicated bench grinder for this setup. On it, I have mounted a diamond taper cup wheel (for carbide), and a aluminum oxide straight cup wheel (for HHS).
One thing Mr. Hall did not include in his books (at least in those I have) is a jig to hold a single point diamond dressing tool, for Aluminum Oxide wheels, that will work with his Deluxe Grinding table.
Has anyone here built this table? What custom jigs did you come up with? Do you have a jig for a single point diamond dresser?
Ive seen dresser jigs advertised and written about on woodworking sites and some of them set the single point diamond pointing directly toward the center of the wheel, some point the diamond downward at 10 degrees to the center of the wheel. Which is best?
I want to build a diamond dressing tool jig from CRS to work with Mr. Halls table. Any advice or pictures of your setups would be appreciated.
Chuck
Chuck
