broke my mill
itowbig
oh dang i broke my mill. the plastic gear on the inside not the on i can get to on the out side . that would be way to easy.
guess i got to finish the belt drive now ;D ok got to go get the belt drive finished now just needed to type this out to get my frustration out a bit :big: funny how just a bit of typing can relieve some stress Thm:
Dang? Ya that be a dang moment. Not to Jinx em, but wait till Zee pops the gear in his mill. :) Maybe a short write up on the change over would help some of those not so Nut-n-Bolt inclined to tackle the switch before, ah, a good "Dang" once in a while is good for the soul.
Robert
You'll like the belt drive.
After you get into that case and remove the broken plastic
gears you will find throwing the pieces across the shop
very satisfying. I know I did! ;)
Rick
Itowbig:
I think you will love the belt conversion it will calm the little beast. Will run much quieter and smoother.
I be jinxed. Thank you.
It hasn't happened yet...but I know Murphy very very well.
itowbig: Please post your travels. I will be very very interested...and appreciative. Oh...and if you happen to make the mod to increase Z....ohhhh..that's very much cherries on top.
I too would like to see the "inards".....if you would please. :)
I fitted the belt drive from the Little Machine Shop and its great.
I also took lots of photos and posted a thread here of it being installed.
Its very simple to do and gives a great improvement.
Here is a true to life comparison between the fragile plastic
gear drive and the belt drive. Both of these videos are from
my own X2 mini mill.
First the gear drive:
[ame]http://www.youtube.com/watch?v=u_zebnE_Zj8[/ame]
And then the belt drive:
[ame]http://www.youtube.com/watch?v=ZzuWDfB1-Jc[/ame]
Which would you rather use?
Rick
What RPM can you get?
The best thing that happened was that I burned up the moter on my Micro Mill. That forced me to do a belt drive (I made my own) and now I have up to 9000 RPM :big:
For what most of us do here the increase in RPM really helps
Mark
Mark
What motor did you replace the stock motor with to achieve the extra revs ?
I made my own belt conversion before anything broke. Found nice prints on internet. I also changed a couple things, went to a better grade of bearing, angular contacts, and R-8 spindle when I did it. Mine had the steel gears and I can offer them and the standard pitch screws and dials if someone has a use. Mine is a micro mark and came with these and I'm just about done with cnc conversion.
