Brians Double Cylinder engine running now
Rolland
Camp Verde, AZ
Its mostly complete, I need to make pins for the valves and connecting rods and recut another flywheel. I made a small mistake in now allowing for the cutter on the spokes so altho useable it is not correct.
It runs very well the govenor is perhaps the most time consuming as it has so many small parts and will tax your brain on building fixtures to hold the bottom sliding piece. Also finding a cold monkey to get the brass ball counterweights, (that ain't easy in the summer time).
[youtube=425,350]<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/-NYAdxPOdqY&hl=en&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/-NYAdxPOdqY&hl=en&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>[/youtube]
Roland---You continue to amaze and impress me. You have done a beautifull job on that. As far as I know, you are the only other person to actually build my twin horizontal engine, although I see that the plans have been downloaded over 100 times. ----Brian---(You get a karma point for the engine and another for the governor.)
:bow: :bow:
so beautiful. lovely sound when it runs.
Where are the plans for this engine?
ttrikalin, They should be in the download section of this board.
Ron
