Tony Bird
Senior Member
Hi,
Just before Christmas 2016 a young couple purchased the property next door to where we live. Early in 2017 they submitted plans for a large extension to the property and a few weeks ago in June the builders arrived and started work. A couple of days ago we were told that they had finished - demolishing! We know there have been unexpected problems; among which was woodworm, hence the disappearance of the roof.
A photograph of the 'finished' work taken a few days ago.
If you look closely you might be able to see something mounted on the right hand side of the wide horizontal baton on the white wall. Yesterday I took a closer photograph after it had moved possibly due to a screw failure.
It was obviously well used by the previous occupier judging by the polish on the pegs. At sometime in the future the property will be re-built and there will be a house warming party; along with the usual gifts given at this sort of a 'do' I thought they might like a bit of their original purchase albeit slightly altered. How they will view this gift remains to be seen. I have absolutely no idea what I will do with it but I suspect I will have some time to work things out.
So far the key holder has been removed from the wall.
The steel key pegs have been removed, it has been cleaned and the two securing holes plugged.
A charity shop purchase has supplied a couple of supports. The stem of one of the candle sticks has already been used on another project.
The bases of the candle sticks have been filled with Plaster of Paris.
When dry and flattened the plaster had cork glued to it which has had a protect layer of masking tape applied to it.
This is how it looks at the moment.
What happens next, with what and when is anybody's guess.
Regards Tony.
Regards Tony.
