Peter Moyes
- Sep 2, 2010
- 7
- 0
I have just joined and have also just started into model engineering. My first project has been to build a boiler in accordance with the instructions contained in that excellent book, Making Simple Steam Engines. I now have a simple boiler can made of copper with a mild steel sheet support cage which is 80mm in diameter and 300mm long and which I have cased in timber planks to provide lagging which is suggested in the book. I have screwed the completed assembly for which I still have to make the safety valve onto a timber base with enough room to fix the actual steam engine when I build that. I am currently making a methylated spirits burner. Now the book says it should be made of brass. I don't have any brass and am making it out of copper and silver soldering the bits together. My question is: Is there a reason why it should be made of brass and not copper or any other material? And, given the size of the boiler, is there a better way of heating the water? Pete mentioned gas, but I wouldn't have clue how to go down that track.
Peter Moyes
Peter Moyes
