Those are some nice plaques.
The letters look surprisingly clean and crisp.
I ran across another video of one of the "ingot-guys" pouring some gray iron ingots using a naturally aspirated propane burner.
I was not aware the cast iron could be melted with a naturally aspirated propane burner, but here is the video.
This ingot-guy makes some rookie mistakes, but does pretty well considering his equipment.
The propane tank generally has to be put in a tub of warm water to allow it to vaporized fast enough to hold a significant enough pressure to melt iron.
And normally one uses some sort of combustion air blower with a propoane burner to help melt the iron, such as a hair dryer, the output from a shop vac, a leaf blower, or some similar device.
I have seen several folks use crucibles that were not a "Morgan Salamander Super" clay graphite "ferrous-metal-rated" crucible, and every time the crucible either leaks or folds up like a wet paper sack.
One guy said "the salesman said it was iron rated"; don't believe salesmen.
And the ingot he cast is full of holes; not sure what exactly is going on with that.
But to give credit where credit is due, the ingot guy melts and pours gray iron, so that is a significant accomplishment I think.
The satanite-coated ceramic blanket furnaces seem to be capable of melting iron without much trouble, but a furnace with a 1" hotface of refractory such as Mizzou will far outlast a coated satanite-coated ceramic blanket.
The furnace lid interior can be a problematic area, and I see a lot of furnace failures starting at the lid interior.
A domed 1" Mizzou lid interior will not fail even if it cracks, and it withstands iron temperatures and splattered iron slag very well.
