wannasteam
- Dec 22, 2009
- 20
- 0
Hello all
I just got a brand new G0602 lathe.
It is all good except when I use the leadscrew with powerfeed.
I get these bands (see photos) on the surface. They are quite rough as can be seen on the pix.
I tried the ff:
1 changing gears,
2 different tools,
3 hard/soft materials,
4 various speeds
5 check the run out of leadscrew (.003" TIR) and is the same with/without the halfnuts engaged.
6 running the cut without the bearing block at the tailstock end
7 do a cut without the powerfeed. Results were as good as I could get it manually but no banding.
8 cleaned the leadscrew real well
9 slackened off completely the gib adjusters for the half nuts, first one, then the other then both
As close as I can figure, it seems to be related to the leadscrew somehow. The pitch of the bands/ridges seems to be the same as that of the leadscew.
There is no discernible in/out movement of the saddle/compound as it traverses.
None of the steps I did made any difference. :'(
I'm kinda stumped here so any ideas from the collective wisdom?
regards and thanks in advance
Joe
I tried the ff:
1 changing gears,
2 different tools,
4 various speeds
Joe
