Ball turning tool
Herbiev
On several occasions I have needed a radius turning tool and just wondering which tool is the best buy both in cost and ease of operation
For me the important things with a ball cutter are:
1) Ridgidity in the cut. A good long handle is important also.
2) Smoothness of the swing bearings/bushings.
3) Ease of making small adjustments of the tool bit. Some sort of
fine pitch thread is a requirement, with, of course, a positive lock.
Thanks for the response. I really like the simplicity of the boring head idea. Off to get a block of aluminium and give it a try.
Herbie, good luck with it. As others have found, make sure you give some thought to the position of the boring head in relation to the lathe centre so you can maximise the work envelope (eg. don't let the cutter go too far past the centre line). I put a fair bit of thought into this.
