As far as models that I am sure are complete, and could be printed now, they are the following:
1. Inner muffler half.
2. Outer muffler half.
3. Crankshaft.
4. Cylinder head.
5. Lid for the water hopper.
6. I think the valve chamber is ready.
7. The crankcase cover needs a little more detailing.
8. The piston is ready.
9. The base I roughed out is not really final, and I did not have anything to go by when I made that 3D model.
I am not really sure why they made the base that Fidlstyks posted the way that they did.
This is the bottom of the crankcase on Barney's 4hp engine, and this is how I modeled mine.
I am not going to change the crankcase on mine, so the base will have to attach under the feet.
I want the flywheels to clear the ground by about 1 inch, with the engine on the base.
If the engine is too top heavy, I can add weight in the base, such as sand, or whatever.
The base may be a good candidate to cast in 356 aluminum, since it is a static item with no wearing surfaces.
10. The crankcase/cylinder is pretty much ready, but I need to verify the boss locations.
I need to look at the water jacket again to be sure I can make that core.
The crankcase will require four patterns, and then some coreboxes.
I may try to combine patterns and coreboxes on the crankcase/frame.
I recently acquired some ferromagnesium, and so I may try to cast the crankshaft in ductile iron.
I will have to get some plastic refractory to line the reaction chamber.
I think that will be all the large patterns/castings.
I think there may be some fidgety small pieces to cast, like the governor weight, etc.
