My scale of the 7hp with subbase has 9 3/8" flywheels. How.tall will yours be?
On the Baker Monitor FB I posted all available pictures, I have learned earlier 6 hp Monitors used a weight added on and the later were 7 hp with hollowed out areas.
I have patterns for the hopper cover, muffler, head and still of course have the whole.engine if some one needs anything made. I know of a guy who was said to be making a valve chest, and I have been messaged from Canada by another guy to make a valve chest for another engine, and I knew of a spare hopper and another guy hunting a hopper. Maybe they were a 2 and a 4 hp's.
My 4hp Monitor scale engine will be half scale, so the flywheels will be 14 inch diameter.
I decided to go big; why not push the limits ?
No sense building a Monitor with 9 inch flywheels, since Lone Star and Pacific have already produced many kits for that scale.
Overall height of my engine will be about 28 inches with the engine mounted on a base, and flywheels clearing the ground.
Are you in Joe Prindle's fb group ?
Sounds like you have a motherload of Ball Hopper Monitor information.
I have no doubt that I could make full size Monitor iron castings.
I just don't know anyone who needs them, and I don't have full sized patterns.
If the casting is large enough, then a double melt/pour would have to be done, but I do have two furnaces, and so could pour perhaps 200 lbs of iron at one time.
I use a pouring cart for the heavier pours, and that makes it easy to handle a #30 full of iron.
I use large diameter wheels so I can use it in the grass, as well as on hard surfaces.
No rubber tires on my cart, since those will catch fire.
I have a crane, for lifting out a #30 crucible.
I often pour at night, due to how hot and humid it gets here during the summer.
Here is an iron pour using the crane and pouring cart.
This was very early in my backyard casting days, and I have changed quite a bit, such as moving everything far away from the garage, and not interrupting the pour.
I did not really have a good feel for foundry work at the time I made this video, but I was learning.
That is a bilge #30 with iron.
