aonemarine
- Nov 18, 2012
- 887
- 212
So what temp did you use to burn out the PLA? I want to do this as well for aluminum casting. I have read that PLA leaves ash residue. Did you burn out the mold with the sprue up or down?
Don
Great job with the castings. Very interested in this method of Casting instead of using Sand Molds. Would be interested in hearing your procedure to get such good castings. I would call these Castings perfect.
Questions
What are you using for the Slurry coat and how many coats did you use? Did you add sand after each coat?
I would like to try lost PLA Casting with aluminum. Hope you don't mined the questions.
Willy
Excellent! Do you have further info on the whole process?
I guess the entire process...I can just look it up, but your results are so great that if you have any other info showing the process i would love to see it. I'm in process of setting up for a lost wax foundry at the moment, but tis for smallish stuff only. I'd like to do bigger eventually.
Nice Job! Thanks for sharing. Do you have videos of the 3D print in action?
Interesting...I never thought of that! Lots to learn here but aonemarine's results certainly are great!
