Here are a few problems I ran into when I was learning to cast aluminum 356.
Aluminum alloy 356 is what is commonly used to make aluminum castings.
Aluminum cans are often seen melted on ytube, but that is not really a good casting allow, in my opinion, and residual moisture inside the can can cause an explosion in the crucible.
I started learning how to cast aluminum in 2011, and a lot of it was trial and error.
You can hopefully avoid these mistakes.
Edit:
I included some problems I had with brass/bronze, and also problems I had with gray iron castings.
Edit:
