It's finally time to make the piston rings so I can do the final assembly. The method I use is a combination of both the Chaddock and Trimble processes. Using the suggested calculations from those guys the rings end up being fairly thin which I like. It makes them easier to install and I think they seal better than fat rings.
Making the rings is pretty quick. I use grey cast iron turned into a tube according to the calculations. And then I part them off and lap them to thickness.
Making the holder to heat treat them is a lot more time consuming. There is a calculation for the diameter of the pin that holds the gap open while heat treating. It's a pretty theoretical dimension. I may have got it slightly wrong as I think the maximum diameter of the pin is supposed to be on the center line of the ring ends. But in the end it really makes little difference (IMHO) as long as they are springy when completed.
I only made the jig to hold 5 rings even though I parted off 10 (minus one off spec).
The rings are stacked in the holder and a cap is installed that keeps them in place and seals the container from air. A bolt holds it all together.
I heat the whole thing carefully with a torch to a dull red colour (no more) barely visible in a dark room and held for several minutes.
There is a whole process you are supposed to follow concerning time and temperature but it works fine (for me) approx as described. After heating they are left to cool until room temperature before opening the container. The rings have no scale. They are just dis-coloured and clean up nicely with some very fine steel wool.
While I had the engine all apart I bead blasted all the pieces. I actually used ground glass because it was already in the cabinet and it's a pain to change. It was a bit too coarse for a final finish in my opinion but it is perfect should I choose to paint it. (I probably won't - I don't want to take it all apart again).
In one picture you can see the installed reed valves. The exhaust valve has what's supposed to be a muffler stacked on top of the valve. The exhaust exits through three holes facing down (not visible).
You'll notice what looks like staining on the metal. That's just oil from assembling it. It is easily removed with some brake cleaner making the whole thing a uniform colour.
Some upcoming parts to make are holders for a magnet and a hall sensor so I can trigger the ignition. The ignition will be easy. I'll be using one of my coil driver modules and a car ignition coil.
A carburetor of some sort - I don't like the one in the book.
And finally a cap to glue on the end of that water jacket that I keep forgetting about,
I'm happy to report that the engine has fairly good compression and the valves seem to be doing their thing.
More on that later.
