Mick Knights
Hi. All.
I posted a few weeks back about a problem I was experiencing where a proven program seemed to stall during the cycle especially when cutting in the X- direction. I eventually traced that one back to the coupling clamping screw on the end of the ball screw which was just tight enough to drive in the X+ direction but allowed the coupling to slip when the torque was reversed.
Having solved that one I've now got a problem with the Z axis. The Z zero and T01 offset positions are correct, as since this condition appeared yesterday I've re-set both several times, but on the first Z drive move instead of the cutter traveling to the Z zero face on the work piece in order to pick up its offset it drives to Z-2.5mm. below the Z zero face. This 2.5 is an exact distance because when the Z zero in the program is changed to a Z 2.5 value the cutter will just cut a whisper of material. In order to run a program I now have to program 2.5mm of the total depth as Z+. I don't use CAD/CAM as I'm an old school Gcode man but I do use the wizards on a regular basis, which will become a problem if this condition persists as I'll have to edit all the Z moves. Any suggestions would be welcomed. Bearing in mind I've had my machine for thirteen years with over 2,800 machining hours on the clock the situation I'm experiencing is not likely to be due to setting. Thanks.
