Mosey
I just finished a simple adapter for my 4" RT to the F! Aciera mill. It gives me about 2" additional Z height, and makes mounting the RT a breeze by way of a captive Allen screw in the table.
I hope the pictures tell the story.
I made a round plate, bored a 35 mm(1.375") hole through it, and press fit the 1-3/8" shaft into the plate. You can see the shaft flush with and fitted into the plate. 35 mm happens to be 1.378+_", so a piece of 1-3/8" drill rod (which actually measured 1.3735" rough) just fit into a bored hole of 1.3745". I chilled the shaft in the freezer overnight, and pressed it in on a little arbor press. In like Flynn.
Now, I just put the shaft into the bore in the mill table, and tighten up the 2 Allen screws, and we're ready to go. The plate screws into the back of the Sherline RT with 3 screws.
Nice and easy little project that saves me lots of time.
This little setup is very nice for making tiny engine parts. The little brass plate and body you see are for my water pump.
Sorry about the embarrassing errors I made in my dimensions above, but I have corrected them now. (Again).
