C
cyssis
Guest
Hi!
My name's Evan, and I'm new to the boards.
I've had the idea of creating a stirling or steam turbine powered generator for a long time, and am now trying to get my project underway.
The heat source is already taken care of (a fresnel lens of about 45"x60" biased [not in focus] enough so as not to melt the 'hot' end of the engine),
as is the sun tracking system and mount for both the engine and lens.
My questions come down to two things:
1. Which should I use, a stirling or a turbine?
2. How should I use that to power an AC generator?
Some things to consider for question 1:
I have basic metal machining skills, to include lathe work and welding/ brazing.
I don't have access to a CNC machine.
The entire unit will be outside year-round, and unattended for most of that time (probably a monthly maintenance).
It must be able to start on its own, once the heat is applied. (I'm sure I could do a thermocouple activated starter motor to swing the flywheel in the case I choose a stirling engine, but I'd prefer not to).
It should have relatively low maintenance and construction costs. (I can probably get MOST of the metal donated... although not all.)
I would probably be making a reaction turbine if I went the turbine route... Less technical knowhow required, I think.
Some things to consider for question 2:
I understand I could just couple the shaft of either the turbine or stirling engine to an AC motor, and tada... suddenly it's a generator.
I guess my real question is, "How can I plug this into a power meter?"
My purpose is to build a few of these contraptions on donated money and attach them to the power grid through an electric meter. My state laws (may also be federal) require the electrical company to pay at peak hour cost per kWhr any energy you put into the grid. My electrical knowledge is lacking enough for this to be a stumbling stone, though. If I have the 110 V AC motor plugged into the power outlet, I'm pretty sure it'll run and just take my turbine along for the ride; while sucking power through the meter.
How do I put the power I make from this setup back into the power grid in that case?
Any ideas would be helpful.
I'm really excited to begin work on this project, and have several hands ready to help. I just don't want to waste their time and mine.
Thanks in advance!
Evan.
[edit]
Also, any links to sturdy & resizable stirling and steam turbine engine plans would be great!
[/edit]
Thanks in advance!
Evan.
[edit]
[/edit]
