Hi folks
I have an old Elliot Progress No1 bench drill which is clamped up to a small 3 axis table - which looks like it came from an equally ancient small milling machine. The drill is quite good - heavily made cast iron body, large spindle for a small bench drill, very little run-out.
At the moment, it's great for positioning holes for drilling, but not much use for milling since holding cutters in the 1/2" drill chuck creates too much chatter for anything but really light cuts. I'd like to make a more suitable chuck for milling cutters and perhaps a fly cutter.
The spindle is solid - so no possibility of using a draw bar without a strip down and attempts at boring / modifications - and at the business end rather than female MT2 there is a male 6JT taper with a length of 3/4 x 26tpi thread above, which normally takes the knurled ring which is used to push the chuck off its taper, if one wants to remove it.
I wondered about making a milling chuck with an internal 6JT taper on the back, but also with a 3/4-26 thread to do up on the spindle - since I doubt a taper alone (with no draw bar) will hold for milling. I'd have to put substantial flats in it to help screw it off, since the idea would be for it to be a rather good fit...
What do folks think? And any ideas for the kind of chuck I might need to make, for a variety of small cutters?
cheers
Mark, Manchester, UK
cheers
