Hello again
In reply to questions from Phil and kvom the flywheel is made up of three different pieces, the hub is 12L14 the spoke section the same and the rim is durabar which is a high grade of cast Iron (corect me here I don't know much about it) . The question now is why all the work, to tight to buy a big chunck of 12L14. The for mentioned stuff was scrounged, I like free! If you look on this same page I have Pic that will explane things better.
As the base goes (scrounged again) it;s made of Corian which is used makeing counter tops and the like. this is the first time I worked with it, it machines,taps and polishs very nice. Use a vacuum system when working with it!!! Was happy that it looked so much like concrete, seemed fitting for a base for a mill engine. The brick pattern was a PITA after I was to far into it I wish I never started, but it came out ok. Took over 12 hrs,only worked a bit at a time. Thanks for looking fellows and the kind remarks
Tom
