Here's a tiny engine I built based on a motor from a child's pump up toy.
It's 5.7mm bore x 5mm stroke.
It works like a two stroke - the piston opens the valve at the top of the stroke and it exhausts out the bottom of the cylinder skirt at the bottom of the stroke.
The damn thing is very fiddly - you need to get the upper volume correct for enough compressed air to drive to the end of the stroke and the valve must not leak.
(That's a US Quarter for size reference.)
I overreved it on its first run and broke the valve - so I'm going to "Plan B"
I hope I can get this to work properly before I post more detail on it.
Ken
![tiny1x.jpg](https://proxy.imagearchive.com/827/827d322d0b9852d745cebc8677dd64e8.jpg)
Ken
