- Aug 25, 2007
- 3,890
- 715
I've been plagued by a leaky inlet valve stem on my Henry Ford engine since the day I finished it. You'd think making a tighter fitting valve would be the obvious answer, but somehow that's eluded me. If only I didn't have to have a pesky valve stem sticking out through a hole.
So, I replaced the poppet valve and spring with a ball bearing and a neodymium magnet. The ball bearing is seated on the inside and the magnet holds the bearing on the seat, obviating the need for a spring. He's a rough drawing and a couple of photos as well as a video showing the engine running happily with the ball bearing inlet valve. It's idling a little rough because I hadn't adjusted the fuel mixture since it warmed up. But it actually does run a lot better now.
And the video
[ame=http://www.youtube.com/watch?v=YGMaWG2BK7Q]http://www.youtube.com/watch?v=YGMaWG2BK7Q[/ame]
Chuck
And the video
Chuck
